Motor/Pump Control Box, Simplex Control Panel, Phase 3, Voltage 208/240/480, Amps 13.0-18.0, Enclosure Type NEMA 4X, Height 12 In, Width 10 In, Depth 6 In, Mounting Wall, Standards UL 508A, Includes Mechanical Float Switches, Fused Control Step Down Transformer, Control Circuit Protection, Magnetic Motor Contactor, Motor Protective Switch, High Level Alarm with Test-Normal-Silence Switch, Auxiliary Alarm Contacts, Terminal Blocks Features Enclosure Type: NEMA 4X Height (In.) : 12 Phase: 3 Width (In.) : 10 Voltage: 208/240/480 Item: Motor/Pump Control Box Depth (In.) : 6 Type: Simplex Control Panel Includes: Mechanical Float Switches, Fused Control Step Down Transformer, Control Circuit Protection, Magnetic Motor Contactor, Motor Protective Switch, High Level Alarm with Test-Normal-Silence Switch, Auxiliary Alarm Contacts, Terminal Blocks Mounting: Wall Standards: UL 508A Amps: 13 to 18 For Use With: - Thermal Unit Code: - Control Box Type: - Motor/Pump HP: - Accepts: - Control Relay:
Store | Price |
Walmart US | [show price] |
I had previously bought the light sockets at Walmart US. I loved DAYTON 2PZH4 Motor/Pump Control Box, 208/240/480V! I look forward to purchasing DAYTON light sockets in even more colors.
