FEDERAL SIGNAL 371LED-120A Warning Light, LED, Amber, 120VAC
Warning Light, Color Amber, Lamp Type LED, Flashes per Minute 60, Light Output 15,000 Candela, Lamp Life 50,000 hr, Lens Design Screw-on Dome, Lens Material Polycarbonate, Housing Material Aluminum, Mounting Surface, Operating Temp. -31 to 150 Degrees F, Rating NEMA 4X, Power Source 120VAC, Current Drawn 380 mA, Width 9.25", Height 11.38 In, Diameter 9.12", Standards UL, cUL, Includes dome gasket Features Rating: NEMA 4X Light Output: 15,000 Candela Includes: dome gasket Lens Design: Screw-on Dome Color: Amber Height: 11.38" Lens Material: Polycarbonate Standards: UL, cUL Lamp Type: LED Flashes per Minute: 60 Diameter: 9.12" Operating Temp. : -31 to 150 Degrees F Power Source: 120VAC Mounting: Surface Housing Material: Aluminum Item: Warning Light Width: 9.25" Lamp Life: 50,000 hr. Current Drawn: 380 mA
Click for Best Price »
Price comparison
Store Price
Walmart US [show price]
FEDERAL SIGNAL 371LED-120A Warning Light, LED, Amber, 120VAC Review
Nowadays, I am still without any problem connected with FEDERAL SIGNAL 371LED-120A Warning Light, LED, Amber, 120VAC. Many possibilities at responsible price of 949.40
Read more reviews »
