Michigan Wheel propellers are designed for trouble-free service and easy repairability. By using only the finest grade alloys, Michigan Wheel aluminum propellers are stronger than most OEM propellers. The rubber hub bonded inside every Michigan Wheel propeller helps protect expensive shafts, motors, and gear boxes from potential damage caused by underwater impact. Vendor Part Number: 012030Applications: Evinrude/Johnson: 14-28 HP, Non-Thru Hub Exhaust, 13 Tooth Spline, 14 HP, 1988-1989; 25 HP, 1978-1984; 25 HP (Commercial Workhose) , 1978-1991 1994 Newer; 28 HP, 1986-1996
Store | Price |
Overton's | [show price] |
Gander Mountain | [show price] |
Just now unpacked original Michigan Wheel 3-Blade Prop, Pressed Rubber Hub / Aluminum, 9.25 dia x 12, RH. I'm dumbstricken of the propellers!
